Zum Hauptinhalt wechseln
Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement
Was du brauchst
  1. Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement, Base Cover: Schritt 1, Bild 1 von 2 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement, Base Cover: Schritt 1, Bild 2 von 2
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: Schritt 2, Bild 2 von 2
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: Schritt 3, Bild 3 von 3
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: Schritt 4, Bild 3 von 3
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement, Coin Cell (CMOS) Battery: Schritt 5, Bild 1 von 2 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement, Coin Cell (CMOS) Battery: Schritt 5, Bild 2 von 2
    • Disconnect the CMOS battery cable from the motherboard.
  6. Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: Schritt 6, Bild 2 von 2
    • The battery may have a very strong adhesive keeping it from peeling off easily.
    • Peel the battery off.
Abschluss
Delia Padilla
564 Reputation
5 Anleitungen geschrieben
Gateway, Team 1-3, Class Fall 2022 Mitglied von Gateway, Team 1-3, Class Fall 2022
GCC-CLASS-F22S1G3
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 17
Letzte 30 Tage: 30
Insgesamt: 431
