Einleitung
A smooth touch pad with soft clicks, and is compatible with gestures.
Was du brauchst
Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
Flip the device over. Press and hold the power button for a few seconds to discharge any leftover electrical current.
Flip the device back over.
Remove five 3 mm screws that are securing the battery using a Phillips #0 screwdriver.
Lift the battery upwards to remove it completely.
Lift the latch holding down the ribbon cable connected to the touch pad.
Remove the three screws holding down the bracket on the bottom portion of the touch pad using a Phillips #0 screwdriver.
Remove the four screws holding down the bracket on the upper portion of the touch pad using a Phillips #0 screwdriver.
Remove the bracket on the bottom portion of the touchpad by carefully peeling it away, as it is held by adhesives, then set it aside.
