Zum Hauptinhalt wechseln
Dell Inspiron 1721 Hinge Plate Cover Replacement
Was du brauchst
  1. Dell Inspiron 1721 Hinge Plate Cover Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 1721 Hinge Plate Cover Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 Hinge Plate Cover Replacement, Hinge Plate Cover: Schritt 2, Bild 1 von 3 Dell Inspiron 1721 Hinge Plate Cover Replacement, Hinge Plate Cover: Schritt 2, Bild 2 von 3 Dell Inspiron 1721 Hinge Plate Cover Replacement, Hinge Plate Cover: Schritt 2, Bild 3 von 3
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 154
