Zum Hauptinhalt wechseln
Dell Inspiron 1721 LCD Screen Replacement
Was du brauchst
  1. Dell Inspiron 1721 LCD Screen Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 1721 LCD Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 LCD Screen Replacement, Hinge Plate Cover: Schritt 2, Bild 1 von 3 Dell Inspiron 1721 LCD Screen Replacement, Hinge Plate Cover: Schritt 2, Bild 2 von 3 Dell Inspiron 1721 LCD Screen Replacement, Hinge Plate Cover: Schritt 2, Bild 3 von 3
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
  3. Dell Inspiron 1721 LCD Screen Replacement, Keyboard: Schritt 3, Bild 1 von 3 Dell Inspiron 1721 LCD Screen Replacement, Keyboard: Schritt 3, Bild 2 von 3 Dell Inspiron 1721 LCD Screen Replacement, Keyboard: Schritt 3, Bild 3 von 3
    • Remove four 3mm Phillips #1 screws from the top of the keyboard.
    • Use an iFixit opening tool to slide the keyboard upwards toward the display.
    • Slide the keyboard until it is clear of the lock tab, and lift it up to remove.
  4. Dell Inspiron 1721 LCD Screen Replacement, Display Assembly: Schritt 4, Bild 1 von 2 Dell Inspiron 1721 LCD Screen Replacement, Display Assembly: Schritt 4, Bild 2 von 2
    • Loosen the two captive Phillips #0 screws.
    • Remove the cover.
  5. Dell Inspiron 1721 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the antenna connectors from the WLAN card.
  6. Dell Inspiron 1721 LCD Screen Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron 1721 LCD Screen Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron 1721 LCD Screen Replacement: Schritt 6, Bild 3 von 3
    • Remove the 3mm Phillips #0 screw securing the connector to the case ground.
    • Disconnect the display connector.
    • Disconnect the second connector, then remove the cable from the base.
  7. Dell Inspiron 1721 LCD Screen Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 1721 LCD Screen Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 1721 LCD Screen Replacement: Schritt 7, Bild 3 von 3
    • Remove the display cable from the palm rest.
    • Use a spudger to carefully pull the antenna wires through to front of the device.
  8. Dell Inspiron 1721 LCD Screen Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron 1721 LCD Screen Replacement: Schritt 8, Bild 2 von 2
    • Remove the two 3.5 mm Phillips screws that hold the display assembly in place.
    • Lift the assembly straight up to separate it from the body of the device.
  9. Dell Inspiron 1721 LCD Screen Replacement, LCD Screen: Schritt 9, Bild 1 von 2 Dell Inspiron 1721 LCD Screen Replacement, LCD Screen: Schritt 9, Bild 2 von 2
    • Remove the six Phillips #0 screws from the display case.
  10. Dell Inspiron 1721 LCD Screen Replacement: Schritt 10, Bild 1 von 3 Dell Inspiron 1721 LCD Screen Replacement: Schritt 10, Bild 2 von 3 Dell Inspiron 1721 LCD Screen Replacement: Schritt 10, Bild 3 von 3
    • Use an opening tool to remove the locks surrounding the display case.
  11. Dell Inspiron 1721 LCD Screen Replacement: Schritt 11, Bild 1 von 3 Dell Inspiron 1721 LCD Screen Replacement: Schritt 11, Bild 2 von 3 Dell Inspiron 1721 LCD Screen Replacement: Schritt 11, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the eight screws surrounding the LCD display inside the display case.
    • Lift the LCD display up out of the display case.
  12. Dell Inspiron 1721 LCD Screen Replacement: Schritt 12, Bild 1 von 1
    • Remove the display cable from the display case to completely disconnect the LCD display.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 238
