Zum Hauptinhalt wechseln
Einleitung
Located just inside the Inspiron’s access door, removal of the hard drive is designed to be a quick process and a prerequisite for the repair of internal hardware.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Located on the bottom of the laptop’s external shell, there should be two plastic sliding tabs to the right and left of the battery pack. Using your fingers, push these two tabs away from each other, toward the sides of the machine.
    • Located on the bottom of the laptop’s external shell, there should be two plastic sliding tabs to the right and left of the battery pack. Using your fingers, push these two tabs away from each other, toward the sides of the machine.
    • This mechanically unlocks the battery pack from its slot at the back of the machine.
  2. Using your fingernails, pry the battery pack away from the rest of the machine, at the physical seam between the pack and the laptop’s plastic case. This may take some effort to accomplish.
    • Using your fingernails, pry the battery pack away from the rest of the machine, at the physical seam between the pack and the laptop’s plastic case.
    • This may take some effort to accomplish.
    • Remove the battery.
  3. Using a Phillips #000 screwdriver, loosen the two screws at the top left and top right of the access door.
    • Using a Phillips #000 screwdriver, loosen the two screws at the top left and top right of the access door.
    • These two captive screws will loosen but will not separate from the panel.
  4. Using a spudger, pry into the gap in the plastic revealed by loosening the screws.
    • Using a spudger, pry into the gap in the plastic revealed by loosening the screws.
    • Lift off the access panel.
  5. Using a Phillips #000 screwdriver, remove the three 5 mm screws securing the hard drive to the laptop.
    • Using a Phillips #000 screwdriver, remove the three 5 mm screws securing the hard drive to the laptop.
  6. Grabbing from the left of the hard drive, slide the part to the left and pull up, lifting it away from the machine.
    • Grabbing from the left of the hard drive, slide the part to the left and pull up, lifting it away from the machine.
Abschluss
Thomas Griffin
879 Reputation
9 Anleitungen geschrieben
UMass Dartmouth, Team S2-G6, Bailey Spring 2019 Mitglied von UMass Dartmouth, Team S2-G6, Bailey Spring 2019
UMASSD-BAILEY-S19S2G6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 5
Insgesamt: 202
