Zum Hauptinhalt wechseln
Dell Inspiron 17R-5737 Cooling Fans Replacement
Was du brauchst
  1. Dell Inspiron 17R-5737 Cooling Fans Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is off before attempting to remove the battery.
    • Flip over your laptop so that the battery faces you.
  2. Dell Inspiron 17R-5737 Cooling Fans Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 17R-5737 Cooling Fans Replacement: Schritt 2, Bild 2 von 2
    • Slide each latch away from the battery to unlock it.
  3. Dell Inspiron 17R-5737 Cooling Fans Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 17R-5737 Cooling Fans Replacement: Schritt 3, Bild 2 von 2
    • Lift the battery upwards to remove it.
    • Continue holding the latches when removing the battery.
  4. Dell Inspiron 17R-5737 Cooling Fans Replacement, Optical Drive: Schritt 4, Bild 1 von 2 Dell Inspiron 17R-5737 Cooling Fans Replacement, Optical Drive: Schritt 4, Bild 2 von 2
    • Remove one 4.8mm screw with a JIS #00 screwdriver.
    • Remove the optical drive.
  5. Dell Inspiron 17R-5737 Cooling Fans Replacement, Access Panel: Schritt 5, Bild 1 von 1
    • Remove two 4.8mm screws with a JIS #00 screwdriver.
    • Remove the access panel.
  6. Dell Inspiron 17R-5737 Cooling Fans Replacement, Hard Drive: Schritt 6, Bild 1 von 3 Dell Inspiron 17R-5737 Cooling Fans Replacement, Hard Drive: Schritt 6, Bild 2 von 3 Dell Inspiron 17R-5737 Cooling Fans Replacement, Hard Drive: Schritt 6, Bild 3 von 3
    • Remove three 4.8mm screws from the hard drive with a JIS #00 screwdriver.
    • Slide the hard drive to the left.
    • Slide the hard drive to the right and up.
  7. Dell Inspiron 17R-5737 Cooling Fans Replacement, RAM: Schritt 7, Bild 1 von 2 Dell Inspiron 17R-5737 Cooling Fans Replacement, RAM: Schritt 7, Bild 2 von 2
    • Slide the two clips away from the RAM.
    • Lift the RAM out.
  8. Dell Inspiron 17R-5737 Cooling Fans Replacement, Keyboard: Schritt 8, Bild 1 von 1
    • A metal spudger can scratch delicate internal parts. Be extra careful when removing the keyboard.
    • Use a metal spudger to loosen the main frame of the keyboard.
    • A metal spudger should be used instead of a plastic one because a plastic one will probably break.
    • Make sure to get the spudger under the entire keyboard and not just under the keys.
  9. Dell Inspiron 17R-5737 Cooling Fans Replacement: Schritt 9, Bild 1 von 3 Dell Inspiron 17R-5737 Cooling Fans Replacement: Schritt 9, Bild 2 von 3 Dell Inspiron 17R-5737 Cooling Fans Replacement: Schritt 9, Bild 3 von 3
    • Slowly lift the keyboard.
    • Lift the locking flap that holds the ribbon cable in place.
    • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the locking flap.
    • Remove the keyboard.
  10. Dell Inspiron 17R-5737 Cooling Fans Replacement, Palmrest: Schritt 10, Bild 1 von 3 Dell Inspiron 17R-5737 Cooling Fans Replacement, Palmrest: Schritt 10, Bild 2 von 3 Dell Inspiron 17R-5737 Cooling Fans Replacement, Palmrest: Schritt 10, Bild 3 von 3
    • Remove two 1.6mm screws from beneath the optical drive with a JIS #00 screwdriver.
    • Remove the nine remaining 4.8mm screws from the back of the computer with a JIS #00 screwdriver.
  11. Dell Inspiron 17R-5737 Cooling Fans Replacement: Schritt 11, Bild 1 von 3 Dell Inspiron 17R-5737 Cooling Fans Replacement: Schritt 11, Bild 2 von 3 Dell Inspiron 17R-5737 Cooling Fans Replacement: Schritt 11, Bild 3 von 3
    • Remove the two exposed ribbon cables.
    • Remove the palmrest.
  12. Dell Inspiron 17R-5737 Cooling Fans Replacement, Motherboard: Schritt 12, Bild 1 von 1
    • Remove the Wi-Fi chip by pulling upwards.
  13. Dell Inspiron 17R-5737 Cooling Fans Replacement: Schritt 13, Bild 1 von 3 Dell Inspiron 17R-5737 Cooling Fans Replacement: Schritt 13, Bild 2 von 3 Dell Inspiron 17R-5737 Cooling Fans Replacement: Schritt 13, Bild 3 von 3
    • Remove six 4.8mm screws with a JIS #00 screwdriver.
    • Remove two 3.2mm screws with aJIS #00 screwdriver.
    • Disconnect three cables from the front of the motherboard.
    • Slowly lift the motherboard exposing the bottom side.
    • Remove the ribbon cable from the back of the motherboard.
    • Remove the motherboard.
  14. Dell Inspiron 17R-5737 Cooling Fans Replacement, Cooling Fan: Schritt 14, Bild 1 von 2 Dell Inspiron 17R-5737 Cooling Fans Replacement, Cooling Fan: Schritt 14, Bild 2 von 2
    • Remove one 3.2mm screw that connects the fan to the motherboard with a J00 Phillips head screwdriver.
    • Disconnect the cable that connects the fan to the motherboard.
    • Remove the cooling fan.
Abschluss
Mack Chabot
645 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team S3-G7, Bailey Fall 2017 Mitglied von UMass Dartmouth, Team S3-G7, Bailey Fall 2017
UMASSD-BAILEY-F17S3G7
3 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 961
