Ersatzteile
Kein Ersatzteil erforderlich.
  1. Make sure the laptop is off before attempting to remove the battery.
    • Make sure the laptop is off before attempting to remove the battery.
    • Flip over your laptop so that the battery faces you.
  2. Slide each latch away from the battery to unlock it.
    • Slide each latch away from the battery to unlock it.
    • Lift the battery upwards to remove it.
      • Continue holding the latches when removing the battery.
    • Remove two 4.8mm screws with a JIS #00 screwdriver.
    • Remove the access panel.
    • Remove three 4.8mm screws from the hard drive with a JIS #00 screwdriver.
    • Slide the hard drive to the left.
    • Slide the hard drive to the right and up.
Abschluss
Mack Chabot
Mitglied seit 18.10.2017
607 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team S3-G7, Bailey Fall 2017 Mitglied von UMass Dartmouth, Team S3-G7, Bailey Fall 2017
UMASSD-BAILEY-F17S3G7
3 Mitglieder
11 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 18
Insgesamt: 248
