Zum Hauptinhalt wechseln
Dell Inspiron 17R-N7010 Keyboard Replacement
Was du brauchst
  1. Dell Inspiron 17R-N7010 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip over the laptop so the back is facing upwards.
    • Locate the battery compartment.
    • Make sure your laptop is turned off before disassembly.
  2. Dell Inspiron 17R-N7010 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Slide both locks away from the center of the battery.
    • After you hear a click, pull out the battery.
  3. Dell Inspiron 17R-N7010 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • Remove both screws that connect the keyboard to the laptop chassis.
  4. Dell Inspiron 17R-N7010 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Look for the four locks that secure the keyboard on top.
    • Push the lock into the case with a plastic opening tool. It is important to note that each lock has a spring behind it
    • Lift the keyboard up a little bit. A plastic opening tool or nylon spudger can help in lifting the keyboard.
  5. Dell Inspiron 17R-N7010 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Lift the top side of the keyboard up and place it upside down. This enables you to access the keyboard cable, which is connected to the motherboard.
    • Lift up the left side of the brown tab with your fingernail and it will open up at 90-degree angle. This will unlock the connector.
    • Unplug the keyboard connector from the motherboard.
    • Remove the keyboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
waleed
103 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 1,390
