Zum Hauptinhalt wechseln
Dell Inspiron 17R-N7110 RAM Replacement
Was du brauchst
  1. Dell Inspiron 17R-N7110 RAM Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 17R-N7110 RAM Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 17R-N7110 RAM Replacement, Battery: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    • Do not touch any electronic components without wearing the anti-static wrist strap. Failure to do so poses a risk of static electric shock, and may cause damage to components.
    • Place the laptop on a flat surface with the Dell logo upside down.
    • Flip the laptop over. The battery will be in the top center.
  2. Dell Inspiron 17R-N7110 RAM Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 17R-N7110 RAM Replacement: Schritt 2, Bild 2 von 2
    • Slide both the left lock and right lock, towards the center of the battery.
    • Push upwards on the grip on the bottom of the battery to remove it.
  3. Dell Inspiron 17R-N7110 RAM Replacement, RAM: Schritt 3, Bild 1 von 2 Dell Inspiron 17R-N7110 RAM Replacement, RAM: Schritt 3, Bild 2 von 2
    • Using a Phillips #1 screwdriver, unscrew the .7mm screw at the top of the RAM compartment as pictured.
    • Use a metal Jimmy to pry open the RAM cover from the top of the compartment.
  4. Dell Inspiron 17R-N7110 RAM Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 17R-N7110 RAM Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 17R-N7110 RAM Replacement: Schritt 4, Bild 3 von 3
    $7.95
    • Do not touch the RAM sticks without releasing static electricity build up. Make sure you are wearing the anti-static wrist strap, and that the metal clip is attached to a grounded metal object.
    • There are two small plastic prongs to the sides of the first RAM stick. Push the prongs away from each other to release the RAM stick.
    • Gently remove the RAM stick.
    • If your laptop has a second RAM stick located underneath the first one, repeat this step to remove it.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 7
Letzte 30 Tage: 12
Insgesamt: 1,204
