Zum Hauptinhalt wechseln
Einleitung
This guide will walk you through removing and replacing your Dell Inspiron 17R-N7110 RAM stick(s). You will be handling delicate electronic components during this process, so be sure to wear the anti-static wrist strap for this replacement.
  1. Do not touch any electronic components without wearing the anti-static wrist strap. Failure to do so poses a risk of static electric shock, and may cause damage to components. Place the laptop on  a flat surface with the  Dell logo upside down. Flip the laptop over. The battery will be in the top center.
    • Do not touch any electronic components without wearing the anti-static wrist strap. Failure to do so poses a risk of static electric shock, and may cause damage to components.
    • Place the laptop on a flat surface with the Dell logo upside down.
    • Flip the laptop over. The battery will be in the top center.
  2. Slide both the left lock and right lock, towards the center of the battery. Push upwards on the grip on the bottom of the battery to remove it.
    • Slide both the left lock and right lock, towards the center of the battery.
    • Push upwards on the grip on the bottom of the battery to remove it.
  3. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Jetzt kaufen
    iPhone X Fix Kits
    Jetzt kaufen
  4. Using a Phillips #1 screwdriver, unscrew the .7mm screw at the top of the RAM compartment as pictured. Use a metal Jimmy to pry open the RAM cover from the top of the compartment.
    • Using a Phillips #1 screwdriver, unscrew the .7mm screw at the top of the RAM compartment as pictured.
    • Use a metal Jimmy to pry open the RAM cover from the top of the compartment.
  5. Do not touch the RAM sticks without releasing static electricity build up.  Make sure you are wearing the anti-static wrist strap, and that the metal clip is attached to a grounded metal object. There are two small plastic prongs to the sides of the first RAM stick.  Push the prongs away from each other to release the RAM stick. Gently remove the RAM stick.
    • Do not touch the RAM sticks without releasing static electricity build up. Make sure you are wearing the anti-static wrist strap, and that the metal clip is attached to a grounded metal object.
    • There are two small plastic prongs to the sides of the first RAM stick. Push the prongs away from each other to release the RAM stick.
    • Gently remove the RAM stick.
    • If your laptop has a second RAM stick located underneath the first one, repeat this step to remove it.
Abschluss
Emily Cone
1.118 Reputation
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 18
Insgesamt: 231
