Einleitung
Is your computer constantly resetting the time and date? Consider using this guide to replace the CMOS battery in your device.
Was du brauchst
Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
Flip the device over so the backside is facing you.
Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
Using a pair of tweezers, lift the exposed edge of the CMOS battery upward.
Once the CMOS battery has been loosened, remove it from the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
