Einleitung
Are you experiencing problems with loading files and other applications on your computer? Consider using this guide to replace the hard drive.
Was du brauchst
Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
Flip the device over so the backside is facing you.
Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
Remove the three 4mm screws holding battery in place using the Phillips #0 screwdriver.
If there is a piece of tape connecting the hard drive and a small power cord, remove the tape.
Using the Phillips #0 screwdriver, remove the two 4mm screws.
Lift the hard drive slightly out of the device.
Grasp the head of the cable, not the cable itself.
Pull away from the hard drive, removing the data cable. The hard drive may now be fully removed.
