Zum Hauptinhalt wechseln
Dell Inspiron 3148 RAM Replacement
Was du brauchst
  1. Dell Inspiron 3148 RAM Replacement, Back Panel: Schritt 1, Bild 1 von 2 Dell Inspiron 3148 RAM Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 RAM Replacement: Schritt 2, Bild 1 von 1
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 RAM Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 3148 RAM Replacement: Schritt 3, Bild 2 von 2
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 RAM Replacement, RAM: Schritt 4, Bild 1 von 1
    • Locate the RAM chips on the motherboard.
  5. Dell Inspiron 3148 RAM Replacement: Schritt 5, Bild 1 von 1
    • There are two tabs on either side of the RAM chip. Pull them away from the chip.
  6. Dell Inspiron 3148 RAM Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 3148 RAM Replacement: Schritt 6, Bild 2 von 2
    • The RAM chip will pop up out of the slot.
    • Pinch the RAM between two fingers, making minimal contact. Gently pull away from its port.
    • Remove the RAM from the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 Mitglied von UMass Dartmouth, Team S1-G2, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G2
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 295
