Einleitung
Is your computer experiencing problems with loading? Consider using this guide to replace the RAM in your device.
Was du brauchst
Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
Flip the device over so the backside is facing you.
Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
There are two tabs on either side of the RAM chip. Pull them away from the chip.
Pinch the RAM between two fingers, making minimal contact. Gently pull away from its port.
Remove the RAM from the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
