Zum Hauptinhalt wechseln
Dell Inspiron 3148 WLAN Card Replacement
Was du brauchst
  1. Dell Inspiron 3148 WLAN Card Replacement, Back Panel: Schritt 1, Bild 1 von 2 Dell Inspiron 3148 WLAN Card Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 WLAN Card Replacement: Schritt 2, Bild 1 von 1
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 WLAN Card Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 3148 WLAN Card Replacement: Schritt 3, Bild 2 von 2
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: Schritt 4, Bild 1 von 3 Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: Schritt 4, Bild 2 von 3 Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: Schritt 4, Bild 3 von 3
    • Locate the WLAN chip. It is a small wireless network card with two small cables connected to it, one black and one white.
    • Using a Phillips #0 screwdriver, remove the single 2mm screw from the WLAN card.
    • The card should pop right up once the screw is removed.
  5. Dell Inspiron 3148 WLAN Card Replacement: Schritt 5, Bild 1 von 1
    • Remove the two wires by pulling them upward, away from the WLAN card.
  6. Dell Inspiron 3148 WLAN Card Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 3148 WLAN Card Replacement: Schritt 6, Bild 2 von 2
    • Using your fingers, pull the WLAN card up and away from the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 Mitglied von UMass Dartmouth, Team S1-G2, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G2
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 273
