Zum Hauptinhalt wechseln
Dell Inspiron 3542 LCD screen replacement
Was du brauchst
  1. Dell Inspiron 3542 LCD screen replacement, Remove the battery: Schritt 1, Bild 1 von 2 Dell Inspiron 3542 LCD screen replacement, Remove the battery: Schritt 1, Bild 2 von 2
    • Remove the battery by pushing both clips out.
    • Remove the power supply.
  2. Dell Inspiron 3542 LCD screen replacement, Bezel removal: Schritt 2, Bild 1 von 2 Dell Inspiron 3542 LCD screen replacement, Bezel removal: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Jimmy
    $7.95
    • Use Jimmy or another opening tool to remove the screen bezel. Be careful not to damage the bezel.
  3. Dell Inspiron 3542 LCD screen replacement, Screen removal: Schritt 3, Bild 1 von 2 Dell Inspiron 3542 LCD screen replacement, Screen removal: Schritt 3, Bild 2 von 2
    • Loosen the marked screws.
  4. Dell Inspiron 3542 LCD screen replacement, Screen removal: Schritt 4, Bild 1 von 1
    • Remove the marked screws.
  5. Dell Inspiron 3542 LCD screen replacement, Screen removal: Schritt 5, Bild 1 von 1
    • The screen can now be removed safely. You can put it screen down at your keyboard.
    • Be careful with the screen.
    • Be careful you don't break the cable connecting the screen.
  6. Dell Inspiron 3542 LCD screen replacement, Cable removal: Schritt 6, Bild 1 von 3 Dell Inspiron 3542 LCD screen replacement, Cable removal: Schritt 6, Bild 2 von 3 Dell Inspiron 3542 LCD screen replacement, Cable removal: Schritt 6, Bild 3 von 3
    $3.99
    • Remove the sticker holding the cable in place.
    • Use Tweezer to remove the safety holding the cable in place.
    • Use Spudger to remove the cable connecting the screen. Be careful whilst removing it.
Abschluss
Grab your new screen and do all the steps in reverse order.
4 weitere Personen haben diese Anleitung absolviert.
nl en
100%
Hier starten ›
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 20
Letzte 30 Tage: 38
Insgesamt: 3,254
