Was du brauchst
Remove the screws that secure the hard-drive assembly to the palm-rest assembly
Open the latch and disconnect the hard-drive cable from the system board
Lift the hard-drive assembly off the palm-rest assembly
Disconnect the interposer from the hard-drive assembly.
Remove the screws that secure the hard-drive bracket to the hard drive and lift it off the hard drive.
Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
Replace the screws that secure the hard-drive bracket to the hard drive
Connect the interposer to the hard-drive assembly
Align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly
Replace the screws that secure the hard-drive assembly to the palm-rest assembly.
Slide the hard-drive cable into the system-board connector and close the latch to secure the cable.
2 weitere Personen haben diese Anleitung absolviert.
