Zum Hauptinhalt wechseln
Dell Inspiron 3847 RAM Stick Replacement
Was du brauchst
  1. Dell Inspiron 3847 RAM Stick Replacement, RAM Stick: Schritt 1, Bild 1 von 1
    • Shut off and power down the PC by turning the switch to the off position, located on the back of the PC.
    • Unplug the power cable and remove any and all peripherals connected to PC.
  2. Dell Inspiron 3847 RAM Stick Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 3847 RAM Stick Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 3847 RAM Stick Replacement: Schritt 2, Bild 3 von 3
    • Lay your PC flat on its side with the 'Inspiron' Logo facing up.
    • Remove the two Phillips #0 screws from the back side of panel.
    • Slide the side panel off completely.
  3. Dell Inspiron 3847 RAM Stick Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 3847 RAM Stick Replacement: Schritt 3, Bild 2 von 2
    • Gently press down the flaps located on each end of the RAM slots. Remove the RAM stick(s) from the motherboard.
    • Repeat this step for each stick of RAM.
    • The flaps may be stiff when pressing down. Be careful not to use too much force if the RAM stick doesn't come loose.
  4. Dell Inspiron 3847 RAM Stick Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 3847 RAM Stick Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 3847 RAM Stick Replacement: Schritt 4, Bild 3 von 3
    • Align the new memory sticks with the memory slots.
    • Gently press down until a “CLICK” sound is made and flaps are pointing upwards.
    • Repeat this step for each stick of RAM you want to install.
  5. Dell Inspiron 3847 RAM Stick Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 3847 RAM Stick Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 3847 RAM Stick Replacement: Schritt 5, Bild 3 von 3
    • Slide the side panel back into position and screw in with the same screws from Step #2.
    • Plug all peripherals into the PC and switch it back on.
    • Boot up the computer. If no errors appear, then installation is complete!
Abschluss
To check if your RAM is installed correctly, Right-click on My PC, Click Properties, and check Installed Memory under the System heading.
Maninder
171 Reputation
1 Anleitung geschrieben
York University, Team S1-G24, O'Regan Summer 2020 Mitglied von York University, Team S1-G24, O'Regan Summer 2020
YORK-O'REGAN-SU20S1G24
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 24
Letzte 30 Tage: 38
Insgesamt: 1,009
