Zum Hauptinhalt wechseln
Dell Inspiron 5100 (2015) Thermal Paste Replacement
Was du brauchst
  1. Dell Inspiron 5100 (2015) Thermal Paste Replacement, Thermal Paste: Schritt 1, Bild 1 von 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement, Thermal Paste: Schritt 1, Bild 2 von 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement, Thermal Paste: Schritt 1, Bild 3 von 3
    • Use the slider to release and remove the battery.
    • Remove the 11 screws using a small tip Phillips screwdriver.
  2. Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 2, Bild 3 von 3
    • Use a flat screw driver to pry against the angled metal.
    • Remove the 3 small screws that were under the optical drive using a small tip Phillips screwdriver.
  3. Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 3, Bild 3 von 3
    • Use a small flat-head screwdriver to pry up at each point indicated to unclip the keyboard from the chassis.
    • Lift the keyboard 2-3 inches up and carefully disconnect the two ribbon cables by unlatching the mechanism and carefully sliding the cable out horizontally.
    • Place the keyboard to the side.
  4. Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 4, Bild 3 von 3
    • Remove the 5 screws using the small Phillips screwdriver.
  5. Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 5, Bild 3 von 3
    • Grab the bottom panel where the optical drive was and lift straight up.
    • It should start popping clips and then come off without much force required.
    • Pay special attention to not break any plastic clips.
  6. Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 6, Bild 3 von 3
    • Loosen the screws one at a time and repeat until they are fully unscrewed.
    • Unplug the fan cable from the header by sliding it out horizontally.
    • Lift the cooler off the CPU with one hand on the CPU area and one hand on the fan assembly.
  7. Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 7, Bild 3 von 3
    • Using paper towels, q-tips, and isopropyl alcohol, clean off the old thermal paste on the CPU and heatsink.
    • Be careful around the CPU; it is delicate and can be damaged.
  8. Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron 5100 (2015) Thermal Paste Replacement: Schritt 8, Bild 2 von 2
    • Apply a grain of rice amount of thermal paste to the CPU in the indicated spots.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Dominic Treadwell
184 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 26
Insgesamt: 205
