Einleitung
You would need to be removing the keyboard to access the heatsink and fan. If you need to, add a new layer of Arctic Silver Thermal Paste.
Was du brauchst
Starting from the right side of the hinge cover, use the flat end of the spudger to pry up the hinge cover and gently remove it.
Using a Phillips screwdriver remove the four M2 x 3-mm screws holding in the keyboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
