Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Flip the laptop on it's back, so that the bottom is facing up.
    • Flip the laptop on it's back, so that the bottom is facing up.
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  3. Loosen the single Phillips #1 screw.
    • Loosen the single Phillips #1 screw.
    • This screw is attached to the panel and cannot be removed.
  4. Push the highlighted pin outward until the RAM pops slightly out of its socket. Place the new chip in at a slight angle, and push it in and downward until little or none of the gold contacts are visible. Not seating the new DIMMs correctly could cause the device to refuse to POST.
    • Push the highlighted pin outward until the RAM pops slightly out of its socket.
    • Place the new chip in at a slight angle, and push it in and downward until little or none of the gold contacts are visible.
    • Not seating the new DIMMs correctly could cause the device to refuse to POST.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
May Chauvin
201 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 12-34, Maness Spring 2011 Mitglied von Cal Poly, Team 12-34, Maness Spring 2011
CPSU-MANESS-S11S12G34
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 3,813
