Einleitung
You will be able to access wires connecting your screen and replace it if needed.
Was du brauchst
Starting from the right side of the hinge cover, use the flat end of the spudger to pry up the hinge cover and gently remove it.
Using a Phillips screwdriver remove the four M2 x 3-mm screws holding in the keyboard.
Using a Phillips screwdriver remove the two screws (5.8mm) located at the rear of the laptop.
Using a Phillips screwdriver remove the four screws (5.8 mm) located at hinges of the screen.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
