Zum Hauptinhalt wechseln
Einleitung
This guide will demonstrate removing the computer's power supply.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Place the case on its side.
    • Place the case on its side.
    • Locate and remove the two 13.1 mm thumbscrews.
  2. Slide the side panel towards the back and remove.
    • Slide the side panel towards the back and remove.
  3. Locate the power supply in upper-back corner of the case.
    • Locate the power supply in upper-back corner of the case.
  4. Laptop-Akkus
    Wenig Aufwand, große Wirkung.
    Jetzt kaufen
    Laptop-Akkus
    Jetzt kaufen
  5. Remove the two power cables from the motherboard.
    • Remove the two power cables from the motherboard.
  6. Remove the power cables from the CD/DVD drive and hard drive.
    • Remove the power cables from the CD/DVD drive and hard drive.
  7. Locate and remove the four Philips #0 8.9 mm screws on the outside of the case.
    • Locate and remove the four Philips #0 8.9 mm screws on the outside of the case.
  8. Gently remove the power supply from the case.
    • Gently remove the power supply from the case.
Abschluss
12 weitere Nutzer haben diese Anleitung absolviert.
Doug Howe
1.645 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 6-8, Regan Fall 2011 Mitglied von Cal Poly, Team 6-8, Regan Fall 2011
CPSU-REGAN-F11S6G8
4 Mitglieder
18 Anleitungen geschrieben
Cuantos Watts de una Power Supply la Inspiron 530 soporta?
Baldwin E. C. Rafael - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 66
Insgesamt: 24,092
