Einleitung
If your keyboard does not respond to your actions use this guide to replace the keyboard part of your laptop.
Before using this guide inspect the battery life, typically the battery drains the power fast and it may also cause the loss of keyboard power.
Step one-three shows you how to replace the battery.
Before beginning, make sure to power off your laptop completely and disconnect from any external power source.
Was du brauchst
Close the laptop and lay it flat, logo side down.
Make sure that the battery is visible and at the top of the device.
Turn the laptop over and open the device.
Insert the flat end of the spudger into the five notches located at the top of the keyboard and pry the keyboard up by pushing down and up.
Lift up and slide back to release the six notches from the bottom of the keyboard.
Flip the keyboard upside down to access the keyboard cable.
Using the flat end of the spudger, flip the black tab securing the keyboard cable up to remove the keyboard cable.
Remove the keyboard by lifting it off of the laptop.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Thank you so much for this guide! The steps were clear and concise.
