Zum Hauptinhalt wechseln
Dell Inspiron 5675 CMOS Battery Replacement
Was du brauchst
  1. Dell Inspiron 5675 CMOS Battery Replacement, CMOS Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 5675 CMOS Battery Replacement, CMOS Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 5675 CMOS Battery Replacement, CMOS Battery: Schritt 1, Bild 3 von 3
    • Ensure the PC is a dell inspiron 5675.
  2. Dell Inspiron 5675 CMOS Battery Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 5675 CMOS Battery Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the two screws on the side panel using your screwdriver.
  3. Dell Inspiron 5675 CMOS Battery Replacement: Schritt 3, Bild 1 von 1
    • Pull out the side panel using the handle.
  4. Dell Inspiron 5675 CMOS Battery Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 5675 CMOS Battery Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 5675 CMOS Battery Replacement: Schritt 4, Bild 3 von 3
    • The CMOS battery is located on the motherboard, just below the M.2 SATA SSD slot. Use your thumb and nail to pull out the battery from its slot.
  5. Dell Inspiron 5675 CMOS Battery Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 5675 CMOS Battery Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 5675 CMOS Battery Replacement: Schritt 5, Bild 3 von 3
    • After it's removed, grab the replacement battery.
    • Slide half the battery in the slot and use your thumb to push it down.
    • Once you hear a click or see its in place, it has been replaced.
  6. Dell Inspiron 5675 CMOS Battery Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron 5675 CMOS Battery Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron 5675 CMOS Battery Replacement: Schritt 6, Bild 3 von 3
    • Grab the side panel and make sure the hooks match with their corresponding slots.
    • Push the side panel forward and screw the two screws back. (refer to step 2)
  7. Dell Inspiron 5675 CMOS Battery Replacement: Schritt 7, Bild 1 von 1
    • Replacement has been complete.
Ziellinie
Stefan Ciausu
145 Reputation
1 Anleitung geschrieben
York University, Team N-6, Morris Winter 2023 Mitglied von York University, Team N-6, Morris Winter 2023
YORK-MORRIS-W23SNG6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 39
Insgesamt: 642
