Zum Hauptinhalt wechseln
Dell Inspiron 5758 LCD Screen Replacement
Was du brauchst
  1. Dell Inspiron 5758 LCD Screen Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 5758 LCD Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
  2. Dell Inspiron 5758 LCD Screen Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 5758 LCD Screen Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 5758 LCD Screen Replacement: Schritt 2, Bild 3 von 3
    • Slide the battery release switch towards the unlock icon.
    • You should hear a click.
    • Lift and pull the ejected battery to remove it.
  3. Dell Inspiron 5758 LCD Screen Replacement, DC Jack: Schritt 3, Bild 1 von 3 Dell Inspiron 5758 LCD Screen Replacement, DC Jack: Schritt 3, Bild 2 von 3 Dell Inspiron 5758 LCD Screen Replacement, DC Jack: Schritt 3, Bild 3 von 3
    • Remove the one 3mm optical drive screw.
    • Remove the two 8 mm screws.
    • Pry up and remove the access door.
  4. Dell Inspiron 5758 LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove the one 3 mm screw.
    • Remove the bracket.
  5. Dell Inspiron 5758 LCD Screen Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 5758 LCD Screen Replacement: Schritt 5, Bild 2 von 2
    • Unplug the antenna cables.
    • Remove the Wireless Card.
  6. Dell Inspiron 5758 LCD Screen Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 5758 LCD Screen Replacement: Schritt 6, Bild 2 von 2
    • Unplug the hard drive cable.
    • Use a plastic opening tool or your fingernail to pop the tab of the cable connector. Then you will be able to disconnect the cable.
    • Remove the four 8 mm screws.
    • Remove the hard drive.
  7. Dell Inspiron 5758 LCD Screen Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 5758 LCD Screen Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 5758 LCD Screen Replacement: Schritt 7, Bild 3 von 3
    • Remove the two 3 mm screws under the battery.
    • Remove the three 2 mm wafer screws under the optical drive.
    • Remove the ten 8 mm base screws.
  8. Dell Inspiron 5758 LCD Screen Replacement: Schritt 8, Bild 1 von 1
    • Unplug the speaker cable by sliding to the right.
  9. Dell Inspiron 5758 LCD Screen Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron 5758 LCD Screen Replacement: Schritt 9, Bild 2 von 2
    • Press in the tabs to loosen the keyboard.
    • Carefully lift the keyboard up and turn it over.
  10. Dell Inspiron 5758 LCD Screen Replacement: Schritt 10, Bild 1 von 1
    • Unplug the keyboard cable & remove the keyboard.
  11. Dell Inspiron 5758 LCD Screen Replacement: Schritt 11, Bild 1 von 2 Dell Inspiron 5758 LCD Screen Replacement: Schritt 11, Bild 2 von 2
    • Slide the DVD optical drive over & remove it from the laptop.
  12. Dell Inspiron 5758 LCD Screen Replacement: Schritt 12, Bild 1 von 2 Dell Inspiron 5758 LCD Screen Replacement: Schritt 12, Bild 2 von 2
    • Remove the four 5 mm screws.
    • Unplug the optical drive interposer cable.
  13. Dell Inspiron 5758 LCD Screen Replacement: Schritt 13, Bild 1 von 2 Dell Inspiron 5758 LCD Screen Replacement: Schritt 13, Bild 2 von 2
    • Unplug the power button cable.
    • Unplug the touchpad cable.
  14. Dell Inspiron 5758 LCD Screen Replacement: Schritt 14, Bild 1 von 3 Dell Inspiron 5758 LCD Screen Replacement: Schritt 14, Bild 2 von 3 Dell Inspiron 5758 LCD Screen Replacement: Schritt 14, Bild 3 von 3
    • Carefully pry off & loosen the bottom base.
  15. Dell Inspiron 5758 LCD Screen Replacement: Schritt 15, Bild 1 von 1
    • Remove the bottom base.
  16. Dell Inspiron 5758 LCD Screen Replacement: Schritt 16, Bild 1 von 2 Dell Inspiron 5758 LCD Screen Replacement: Schritt 16, Bild 2 von 2
    • Remove the one 5mm screw.
    • Lift the circuit board & turn it over.
    • Unplug the cable.
    • Remove the audio/USB circuit board.
  17. Dell Inspiron 5758 LCD Screen Replacement: Schritt 17, Bild 1 von 3 Dell Inspiron 5758 LCD Screen Replacement: Schritt 17, Bild 2 von 3 Dell Inspiron 5758 LCD Screen Replacement: Schritt 17, Bild 3 von 3
    • Loosen the audio / USB cable.
    • Remove the one 3mm motherboard screw.
    • Lift the motherboard & carefully move it out of the way.
  18. Dell Inspiron 5758 LCD Screen Replacement: Schritt 18, Bild 1 von 3 Dell Inspiron 5758 LCD Screen Replacement: Schritt 18, Bild 2 von 3 Dell Inspiron 5758 LCD Screen Replacement: Schritt 18, Bild 3 von 3
    • Unplug the DC jack cable.
    • Remove the one 3mm screw.
    • Remove the DC Jack.
  19. Dell Inspiron 5758 LCD Screen Replacement, Touchpad: Schritt 19, Bild 1 von 2 Dell Inspiron 5758 LCD Screen Replacement, Touchpad: Schritt 19, Bild 2 von 2
    • Release the antenna cable tape.
    • Release the antenna cables.
  20. Dell Inspiron 5758 LCD Screen Replacement: Schritt 20, Bild 1 von 3 Dell Inspiron 5758 LCD Screen Replacement: Schritt 20, Bild 2 von 3 Dell Inspiron 5758 LCD Screen Replacement: Schritt 20, Bild 3 von 3
    • Remove the four 5mm right hinge screws using the Phillips #00 screwdriver.
    • Remove the three 5mm left hinge screws using Phillips #00 screwdriver.
    • Open the hinges carefully and remove the LCD display assembly.
  21. Dell Inspiron 5758 LCD Screen Replacement: Schritt 21, Bild 1 von 2 Dell Inspiron 5758 LCD Screen Replacement: Schritt 21, Bild 2 von 2
    • Remove the one 2mm wafer screw using Phillips #0 screwdriver.
    • Loosen the cable and remove the power button circuit board.
  22. Dell Inspiron 5758 LCD Screen Replacement: Schritt 22, Bild 1 von 2 Dell Inspiron 5758 LCD Screen Replacement: Schritt 22, Bild 2 von 2
    • Push up on the touchpad to release it from the housing.
    • Remove the touchpad.
  23. Dell Inspiron 5758 LCD Screen Replacement, LCD Screen: Schritt 23, Bild 1 von 3 Dell Inspiron 5758 LCD Screen Replacement, LCD Screen: Schritt 23, Bild 2 von 3 Dell Inspiron 5758 LCD Screen Replacement, LCD Screen: Schritt 23, Bild 3 von 3
    • Once you have removed the LCD display assembly from the palmrest touchpad, use a spudger to unsnap the LCD bezel via the notches on the outside edge of the bezel .
    • The bezel may require some force to unsnap.
    • When you have removed the LCD bezel, place it to the side.
  24. Dell Inspiron 5758 LCD Screen Replacement: Schritt 24, Bild 1 von 3 Dell Inspiron 5758 LCD Screen Replacement: Schritt 24, Bild 2 von 3 Dell Inspiron 5758 LCD Screen Replacement: Schritt 24, Bild 3 von 3
    • Remove the ten 4.5mm screen screws.
    • There is one screw in the top left, one screw in the top right, four in the bottom left, and four in the bottom right.
  25. Dell Inspiron 5758 LCD Screen Replacement: Schritt 25, Bild 1 von 2 Dell Inspiron 5758 LCD Screen Replacement: Schritt 25, Bild 2 von 2
    • Lift the LCD screen from the display assembly, flip the LCD screen over, and place the screen face down.
    • Unplug the LCD cable.
    • Place the display assembly to the side.
  26. Dell Inspiron 5758 LCD Screen Replacement: Schritt 26, Bild 1 von 2 Dell Inspiron 5758 LCD Screen Replacement: Schritt 26, Bild 2 von 2
    • Remove the three 3mm screws that connect each hinge rail to the LCD screen.
    • Remove the hinge rails.
    • There are two hinge rails, one on the left edge of the screen and one on the right edge.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Blase Martin
407 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 16
Insgesamt: 896
