Zum Hauptinhalt wechseln
Dell Inspiron 5758 Touchpad Replacement
Was du brauchst
  1. Dell Inspiron 5758 Touchpad Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 5758 Touchpad Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
  2. Dell Inspiron 5758 Touchpad Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 5758 Touchpad Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 5758 Touchpad Replacement: Schritt 2, Bild 3 von 3
    • Slide the battery release switch towards the unlock icon.
    • You should hear a click.
    • Lift and pull the ejected battery to remove it.
  3. Dell Inspiron 5758 Touchpad Replacement, DC Jack: Schritt 3, Bild 1 von 3 Dell Inspiron 5758 Touchpad Replacement, DC Jack: Schritt 3, Bild 2 von 3 Dell Inspiron 5758 Touchpad Replacement, DC Jack: Schritt 3, Bild 3 von 3
    • Remove the one 3mm optical drive screw.
    • Remove the two 8 mm screws.
    • Pry up and remove the access door.
  4. Dell Inspiron 5758 Touchpad Replacement: Schritt 4, Bild 1 von 1
    • Remove the one 3 mm screw.
    • Remove the bracket.
  5. Dell Inspiron 5758 Touchpad Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 5758 Touchpad Replacement: Schritt 5, Bild 2 von 2
    • Unplug the antenna cables.
    • Remove the Wireless Card.
  6. Dell Inspiron 5758 Touchpad Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 5758 Touchpad Replacement: Schritt 6, Bild 2 von 2
    • Unplug the hard drive cable.
    • Use a plastic opening tool or your fingernail to pop the tab of the cable connector. Then you will be able to disconnect the cable.
    • Remove the four 8 mm screws.
    • Remove the hard drive.
  7. Dell Inspiron 5758 Touchpad Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 5758 Touchpad Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 5758 Touchpad Replacement: Schritt 7, Bild 3 von 3
    • Remove the two 3 mm screws under the battery.
    • Remove the three 2 mm wafer screws under the optical drive.
    • Remove the ten 8 mm base screws.
  8. Dell Inspiron 5758 Touchpad Replacement: Schritt 8, Bild 1 von 1
    • Unplug the speaker cable by sliding to the right.
  9. Dell Inspiron 5758 Touchpad Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron 5758 Touchpad Replacement: Schritt 9, Bild 2 von 2
    • Press in the tabs to loosen the keyboard.
    • Carefully lift the keyboard up and turn it over.
  10. Dell Inspiron 5758 Touchpad Replacement: Schritt 10, Bild 1 von 1
    • Unplug the keyboard cable & remove the keyboard.
  11. Dell Inspiron 5758 Touchpad Replacement: Schritt 11, Bild 1 von 2 Dell Inspiron 5758 Touchpad Replacement: Schritt 11, Bild 2 von 2
    • Slide the DVD optical drive over & remove it from the laptop.
  12. Dell Inspiron 5758 Touchpad Replacement: Schritt 12, Bild 1 von 2 Dell Inspiron 5758 Touchpad Replacement: Schritt 12, Bild 2 von 2
    • Remove the four 5 mm screws.
    • Unplug the optical drive interposer cable.
  13. Dell Inspiron 5758 Touchpad Replacement: Schritt 13, Bild 1 von 2 Dell Inspiron 5758 Touchpad Replacement: Schritt 13, Bild 2 von 2
    • Unplug the power button cable.
    • Unplug the touchpad cable.
  14. Dell Inspiron 5758 Touchpad Replacement: Schritt 14, Bild 1 von 3 Dell Inspiron 5758 Touchpad Replacement: Schritt 14, Bild 2 von 3 Dell Inspiron 5758 Touchpad Replacement: Schritt 14, Bild 3 von 3
    • Carefully pry off & loosen the bottom base.
  15. Dell Inspiron 5758 Touchpad Replacement: Schritt 15, Bild 1 von 1
    • Remove the bottom base.
  16. Dell Inspiron 5758 Touchpad Replacement: Schritt 16, Bild 1 von 2 Dell Inspiron 5758 Touchpad Replacement: Schritt 16, Bild 2 von 2
    • Remove the one 5mm screw.
    • Lift the circuit board & turn it over.
    • Unplug the cable.
    • Remove the audio/USB circuit board.
  17. Dell Inspiron 5758 Touchpad Replacement: Schritt 17, Bild 1 von 3 Dell Inspiron 5758 Touchpad Replacement: Schritt 17, Bild 2 von 3 Dell Inspiron 5758 Touchpad Replacement: Schritt 17, Bild 3 von 3
    • Loosen the audio / USB cable.
    • Remove the one 3mm motherboard screw.
    • Lift the motherboard & carefully move it out of the way.
  18. Dell Inspiron 5758 Touchpad Replacement: Schritt 18, Bild 1 von 3 Dell Inspiron 5758 Touchpad Replacement: Schritt 18, Bild 2 von 3 Dell Inspiron 5758 Touchpad Replacement: Schritt 18, Bild 3 von 3
    • Unplug the DC jack cable.
    • Remove the one 3mm screw.
    • Remove the DC Jack.
  19. Dell Inspiron 5758 Touchpad Replacement, Touchpad: Schritt 19, Bild 1 von 2 Dell Inspiron 5758 Touchpad Replacement, Touchpad: Schritt 19, Bild 2 von 2
    • Release the antenna cable tape.
    • Release the antenna cables.
  20. Dell Inspiron 5758 Touchpad Replacement: Schritt 20, Bild 1 von 3 Dell Inspiron 5758 Touchpad Replacement: Schritt 20, Bild 2 von 3 Dell Inspiron 5758 Touchpad Replacement: Schritt 20, Bild 3 von 3
    • Remove the four 5mm right hinge screws using the Phillips #00 screwdriver.
    • Remove the three 5mm left hinge screws using Phillips #00 screwdriver.
    • Open the hinges carefully and remove the LCD display assembly.
  21. Dell Inspiron 5758 Touchpad Replacement: Schritt 21, Bild 1 von 2 Dell Inspiron 5758 Touchpad Replacement: Schritt 21, Bild 2 von 2
    • Remove the one 2mm wafer screw using Phillips #0 screwdriver.
    • Loosen the cable and remove the power button circuit board.
  22. Dell Inspiron 5758 Touchpad Replacement: Schritt 22, Bild 1 von 2 Dell Inspiron 5758 Touchpad Replacement: Schritt 22, Bild 2 von 2
    • Push up on the touchpad to release it from the housing.
    • Remove the touchpad.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Majed
196 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 19
Insgesamt: 676
