Zum Hauptinhalt wechseln
Dell Inspiron 6000 DVD/CD Drive Replacement
Was du brauchst
  1. Dell Inspiron 6000 DVD/CD Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 DVD/CD Drive Replacement: Schritt 2, Bild 1 von 1
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 DVD/CD Drive Replacement, Removing the DVD/CD Drive Screw: Schritt 3, Bild 1 von 1
    • Remove one 4mm Philips #00 screw.
  4. Dell Inspiron 6000 DVD/CD Drive Replacement, Inserting Paper Clip: Schritt 4, Bild 1 von 1
    • Open the paperclip as seen here.
    • Insert the paper clip into small hole next to the eject button on the disk drive.
  5. Dell Inspiron 6000 DVD/CD Drive Replacement, Popping Out the DVD/CD Drive: Schritt 5, Bild 1 von 1
    • With slight pressure, push the paperclip into the laptop.
    • The disk drive will slowly "pop out" of the side of the laptop.
  6. Dell Inspiron 6000 DVD/CD Drive Replacement, Completely removing the DVD/CD Drive: Schritt 6, Bild 1 von 1
    • Using your hand, pull the disk drive out of the laptop.
Abschluss
Kenneth Odum
545 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 11-1, Blackwell Fall 2014 Mitglied von USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 1,842
