Einleitung
A dirty or broken fan may create overheating and performance issues. Accessing the fan requires some disassembly and time.
Was du brauchst
Push the switch next to the battery.
At the same time, lift the battery away from the laptop.
Place the laptop on flat surface.
Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
Carefully take a spudger and separate part of the cover at the red circle.
Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
Gently pull the blue tab to separate the screen connection from the laptop.
Gently pull and disconnect the white and black cords from the power source.
Remove four 4mm #00 Philips screws from the screen hinges.
Lift the screen away from the laptop.
Insert the plastic opening tool in between the back and front plates of the laptop
5 weitere Personen haben diese Anleitung absolviert.
