Zum Hauptinhalt wechseln
Dell Inspiron 6000 Screen Replacement
Was du brauchst
  1. Dell Inspiron 6000 Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
    Frag FixBot
    Kommentar hinzufügen
  2. Dell Inspiron 6000 Screen Replacement: Schritt 2, Bild 1 von 1
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
    Frag FixBot
  3. Dell Inspiron 6000 Screen Replacement, Keyboard: Schritt 3, Bild 1 von 3 Dell Inspiron 6000 Screen Replacement, Keyboard: Schritt 3, Bild 2 von 3 Dell Inspiron 6000 Screen Replacement, Keyboard: Schritt 3, Bild 3 von 3
    • Place the laptop on flat surface.
    • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
    • Carefully take a spudger and separate part of the cover at the red circle.
    Frag FixBot
  4. Dell Inspiron 6000 Screen Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 6000 Screen Replacement: Schritt 4, Bild 2 von 2
    • Remove two 4 mm Philips #00 screws.
    Frag FixBot
  5. Dell Inspiron 6000 Screen Replacement: Schritt 5, Bild 1 von 1
    • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
    Frag FixBot
  6. Dell Inspiron 6000 Screen Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron 6000 Screen Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron 6000 Screen Replacement: Schritt 6, Bild 3 von 3
    • Gently pull the blue tab up until it comes away from computer.
    Frag FixBot
  7. Dell Inspiron 6000 Screen Replacement, Screen: Schritt 7, Bild 1 von 1
    • Remove one 4mm Philips #00 screw to completely disengage blue tab.
    Frag FixBot
  8. Dell Inspiron 6000 Screen Replacement: Schritt 8, Bild 1 von 1
    • Pull and disconnect the blue tab.
    Frag FixBot
  9. Dell Inspiron 6000 Screen Replacement: Schritt 9, Bild 1 von 1
    • Disconnect the black and white wires.
    Frag FixBot
  10. Dell Inspiron 6000 Screen Replacement: Schritt 10, Bild 1 von 1
    • Remove four 4mm Philips #00 screws at the hinges for the screen.
    Frag FixBot
  11. Dell Inspiron 6000 Screen Replacement: Schritt 11, Bild 1 von 1
    • Separate the top panel of the laptop from the bottom panel.
    Frag FixBot
  12. Dell Inspiron 6000 Screen Replacement: Schritt 12, Bild 1 von 2 Dell Inspiron 6000 Screen Replacement: Schritt 12, Bild 2 von 2
    • Use the plastic opening tools to remove the six rubber screw covers in the corners.
    • Remove six 4 mm #00 Philips screws located in the corners.
    Frag FixBot
  13. Dell Inspiron 6000 Screen Replacement: Schritt 13, Bild 1 von 2 Dell Inspiron 6000 Screen Replacement: Schritt 13, Bild 2 von 2
    • Insert the plastic opening tools between the screen holders.
    • Go completely around the screen, separating the screen holders with the plastic opening tools.
    Frag FixBot
  14. Dell Inspiron 6000 Screen Replacement: Schritt 14, Bild 1 von 2 Dell Inspiron 6000 Screen Replacement: Schritt 14, Bild 2 von 2
    • Remove 12 4mm #00 Philips screws at the perimeter of the screen.
    Frag FixBot
  15. Dell Inspiron 6000 Screen Replacement: Schritt 15, Bild 1 von 2 Dell Inspiron 6000 Screen Replacement: Schritt 15, Bild 2 von 2
    • Gently lift the screen from the holder.
    • Do not touch the copper part of the bottom side of the screen.
    Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 11-1, Blackwell Fall 2014 Mitglied von USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 32
Insgesamt: 3,071
