Zum Hauptinhalt wechseln
Dell Inspiron 600M Disk Drive Replacement
Was du brauchst
  1. Dell Inspiron 600M Disk Drive Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 600M Disk Drive Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 600M Disk Drive Replacement, Battery: Schritt 1, Bild 3 von 3
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600M Disk Drive Replacement, Disk Drive: Schritt 2, Bild 1 von 1
    • Rotate the computer so that it is upside down and you are facing the rear panel with all the connection ports (You can base your position from the battery location in the image).
  3. Dell Inspiron 600M Disk Drive Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 600M Disk Drive Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 600M Disk Drive Replacement: Schritt 3, Bild 3 von 3
    • Using #00 screwdriver, unscrew the locking screw circled in red.
    • Push in on button directly beneath screw (where the finger is in the image). A tab should pop out as shown in picture 2.
    • Pull out on tab to remove disk drive.
    • Replace old disk drive with new disk drive and go through all steps in reverse to reassemble laptop.
Abschluss
Eric Johnson
13 Reputation
1 Anleitung geschrieben
Cal Poly, Team 10-40, Forte Spring 2011 Mitglied von Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 21
Insgesamt: 3,012
