Zum Hauptinhalt wechseln
Dell Inspiron 600m Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 600m Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 600m Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 600m Hard Drive Replacement, Battery: Schritt 1, Bild 3 von 3
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600m Hard Drive Replacement, Hard Drive: Schritt 2, Bild 1 von 1
    • The hard drive is located here.
  3. Dell Inspiron 600m Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Use a #00 screwdriver to remove the single screw located in the center of the hard drive cover.
  4. Dell Inspiron 600m Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Pull the hard drive tray directly away from the computer. The tray should slide out easily.
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
Todd
146 Reputation
1 Anleitung geschrieben
Cal Poly, Team 10-40, Forte Spring 2011 Mitglied von Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Mitglieder
8 Anleitungen geschrieben
2 Kommentare
What size is the hard drive, you know, to buy a new one?
Ethan White - Antwort
Is it a sata drive compatible or pata? It’s older and most laptops from that year hadn't converted to sata hdd.
physicsguy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 10
Letzte 30 Tage: 44
Insgesamt: 17,323
