Zum Hauptinhalt wechseln
Dell Inspiron 600m Keyboard Replacement
Was du brauchst
  1. Dell Inspiron 600m Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 600m Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 600m Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600m Keyboard Replacement, Keyboard: Schritt 2, Bild 1 von 1
    • Orient laptop with the keyboard facing upward and the lid open.
  3. Dell Inspiron 600m Keyboard Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 600m Keyboard Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 600m Keyboard Replacement: Schritt 3, Bild 3 von 3
    • Caution the face plate is a fragile piece of plastic. Handle carefully.
    • Start in the upper right corner and work to the left when removing the face plate (includes power button and volume controls).
    • Use a flathead screwdriver (or anything flat and strong) to wedge underneath the face plate.
    • Carefully lift the screwdriver to remove the face plate.
  4. Dell Inspiron 600m Keyboard Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 600m Keyboard Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 600m Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Use a the Phillips screwdriver to remove the two screws.
  5. Dell Inspiron 600m Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Gently slide keyboard toward screen.
    • Lift keyboard carefully. It is attached by a ribbon cable.
  6. Dell Inspiron 600m Keyboard Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron 600m Keyboard Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron 600m Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Pull upward on blue tab to disconnect keyboard.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 10-40, Forte Spring 2011 Mitglied von Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 16
Letzte 30 Tage: 21
Insgesamt: 3,513
