Zum Hauptinhalt wechseln
Dell Inspiron 600m LCD Replacement
Was du brauchst
  1. Dell Inspiron 600m LCD Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 600m LCD Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 600m LCD Replacement, Battery: Schritt 1, Bild 3 von 3
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600m LCD Replacement, LCD: Schritt 2, Bild 1 von 2 Dell Inspiron 600m LCD Replacement, LCD: Schritt 2, Bild 2 von 2
    • Using fingernails or a spudger, push any direction on the rubber dots to remove them from the plastic cover.
    • Underneath each rubber dot will be a screw. Remove these screws with the Phillips #00 screwdriver.
  3. Dell Inspiron 600m LCD Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 600m LCD Replacement: Schritt 3, Bild 2 von 2
    • Use the IFixit Opening Tool to un-clip the plastic cover, detaching it from the rest of the screen.
    • There are clips about every inch around the right, left, and top of the plastic cover. Be sure that all of them are unclipped.
  4. Dell Inspiron 600m LCD Replacement: Schritt 4, Bild 1 von 1
    • Pull straight up on the cover to lift the cover off of the rest of the screen.
    • The bottom part of the plastic is a little sticky.
  5. Dell Inspiron 600m LCD Replacement: Schritt 5, Bild 1 von 1
    • Remove four screws (two on each side of the screen) with the Phillips #00 screwdriver.
    • The middle screw does not need to be removed.
  6. Dell Inspiron 600m LCD Replacement: Schritt 6, Bild 1 von 1
    • Gently lift the LCD panel off of the base.
    • The LCD is still attached to the computer. Do not pull too hard or you could break the cable.
  7. Dell Inspiron 600m LCD Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 600m LCD Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 600m LCD Replacement: Schritt 7, Bild 3 von 3
    • Flip the LCD panel over.
    • Do not touch on or near the back of the panel where it says "Don't Touch." LCD panels contain mercury which is hazardous to humans.
    • Remove the cable by squeezing each side of the connector and gently pulling straight out.
  8. Dell Inspiron 600m LCD Replacement: Schritt 8, Bild 1 von 3 Dell Inspiron 600m LCD Replacement: Schritt 8, Bild 2 von 3 Dell Inspiron 600m LCD Replacement: Schritt 8, Bild 3 von 3
    • Remove the cable at the base of the laptop by pulling up on the yellow tab attached to the cable.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Alex Klimaj
143 Reputation
1 Anleitung geschrieben
Cal Poly, Team 10-40, Forte Spring 2011 Mitglied von Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 22
Insgesamt: 6,927
