Zum Hauptinhalt wechseln
Dell Inspiron 6400 keyboard Replacement
Was du brauchst
  1. Dell Inspiron 6400 keyboard Replacement, replacing Keyboard: Schritt 1, Bild 1 von 3 Dell Inspiron 6400 keyboard Replacement, replacing Keyboard: Schritt 1, Bild 2 von 3 Dell Inspiron 6400 keyboard Replacement, replacing Keyboard: Schritt 1, Bild 3 von 3
    • Turn over laptop .Remove battery from laptop by pushing the two tabs are highlighted in blue. Place the battery off to the side.
  2. Dell Inspiron 6400 keyboard Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 6400 keyboard Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 6400 keyboard Replacement: Schritt 2, Bild 3 von 3
    • Remove the 3 screws highlighted in red that secure the keyboard to the case using the screwdriver with largest phillips head in the box. Make
  3. Dell Inspiron 6400 keyboard Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 6400 keyboard Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 6400 keyboard Replacement: Schritt 3, Bild 3 von 3
    • Turn the device right side up and open the device to view the keyboard.
    • Remove the keyboard away from the case ,using a plastic spudger if necessary.
    • The keyboard will still be attached to the motherboard by a ribbon cable.
  4. Dell Inspiron 6400 keyboard Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 6400 keyboard Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 6400 keyboard Replacement: Schritt 4, Bild 3 von 3
    • Replace the new keyboard with plastic spudger.
    • The keyboard will have to be attached to the motherboard by a ribbon cable.
    • Snapped the keyboard back in place.
  5. Dell Inspiron 6400 keyboard Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 6400 keyboard Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 6400 keyboard Replacement: Schritt 5, Bild 3 von 3
    • Flip over the laptop
    • Put the screws back in laptop
  6. Dell Inspiron 6400 keyboard Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 6400 keyboard Replacement: Schritt 6, Bild 2 von 2
    • Place the battery and lock it into place
Abschluss
kempc8
899 Reputation
7 Anleitungen geschrieben
K and K Fixit Mitglied von K and K Fixit
Business
1 Mitglied
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 897
