Zum Hauptinhalt wechseln
Dell Inspiron 700m Hinge Cover Replacement
Was du brauchst
  1. Dell Inspiron 700m  Hinge Cover  Replacement, Removing battery: Schritt 1, Bild 1 von 1
    • Remove the battery by sliding and holding the battery release latch.
    • Make sure your computer is turned off and unplugged.
  2. Dell Inspiron 700m  Hinge Cover  Replacement, Open display: Schritt 2, Bild 1 von 1
    • Open the display 180 degrees.
  3. Dell Inspiron 700m  Hinge Cover  Replacement, Removing Display: Schritt 3, Bild 1 von 1
    • Use a plastic flat screwdriver to slide the hinge caps away from the computer.
    • Detach the two display latches on the back of the computer.
    • Use plastic flat screwdriver to carefully pry up the latches on either side of the hinge cover
    • Carefully, lift the hinge cover from the main unit and remove it from the main unit.
Abschluss
irlanda
11.526 Reputation
2 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 178
