Zum Hauptinhalt wechseln
Dell Inspiron 7306 P125 Battery Replacement
Was du brauchst
  1. Dell Inspiron 7306 P125 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 7306 P125 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn off the laptop with the power button and close it.
    • Disconnect any power sources from the laptop.
  2. Dell Inspiron 7306 P125 Battery Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 7306 P125 Battery Replacement: Schritt 2, Bild 2 von 2
    • Use the Phillips #00 screwdriver to remove the seven M2x4 screws from the back panel of the laptop.
  3. Dell Inspiron 7306 P125 Battery Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 7306 P125 Battery Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 7306 P125 Battery Replacement: Schritt 3, Bild 3 von 3
    • Grab a corner of the back cover or use a spudger to lift the cover.
    • Pull the cover up around the edges until it is completely removed.
  4. Dell Inspiron 7306 P125 Battery Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 7306 P125 Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the three tapes on the left, middle, and right of the battery.
  5. Dell Inspiron 7306 P125 Battery Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 7306 P125 Battery Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 7306 P125 Battery Replacement: Schritt 5, Bild 3 von 3
    • Remove the three M2x3.5 screws that have a screw icon above them with the Phillips #00 screwdriver
    • Do not interact with the object located to the left of the middle screw.
  6. Dell Inspiron 7306 P125 Battery Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 7306 P125 Battery Replacement: Schritt 6, Bild 2 von 2
    • Pull the battery cable towards the direction of the opening.
    • Do not pull the cable upwards.
  7. Dell Inspiron 7306 P125 Battery Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 7306 P125 Battery Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 7306 P125 Battery Replacement: Schritt 7, Bild 3 von 3
    • Insert the new battery. Align the holes of the screwdriver with the center object.
    • Apply the tape from the wires to the battery once more.
    • Ensure that the cover snaps into place when closing the back cover.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
CSU Los Angeles, Team 2-73, Briggs Spring 2023 Mitglied von CSU Los Angeles, Team 2-73, Briggs Spring 2023
CSULA-BRIGGS-S23S2G73
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 26
Letzte 30 Tage: 74
Insgesamt: 1,366
