Zum Hauptinhalt wechseln
Dell Inspiron 7486 Chromebook Battery Replacement
Was du brauchst
  1. Dell Inspiron 7486 Chromebook Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 7486 Chromebook Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Power off your Chromebook and unplug it from the AC adapter before starting.
    • Remove the seven 6 mm screws securing the base cover with a Phillips #1 screwdriver.
  2. Dell Inspiron 7486 Chromebook Battery Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 7486 Chromebook Battery Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the three captive screws with a Phillips #1 screwdriver.
  3. Dell Inspiron 7486 Chromebook Battery Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 7486 Chromebook Battery Replacement: Schritt 3, Bild 2 von 2
    • Gently pry the base cover loose at the hinges with a plastic opening tool.
    • Carefully run your fingertips along the edges of the base cover to remove it.
  4. Dell Inspiron 7486 Chromebook Battery Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 7486 Chromebook Battery Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 7486 Chromebook Battery Replacement: Schritt 4, Bild 3 von 3
    • Using a Phillips #0 screwdriver, remove the two 4 mm screws securing the battery cable bracket to the motherboard.
    • Remove the battery cable bracket.
  5. Dell Inspiron 7486 Chromebook Battery Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 7486 Chromebook Battery Replacement: Schritt 5, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove the four 3 mm screws that secure the battery to the motherboard.
  6. Dell Inspiron 7486 Chromebook Battery Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron 7486 Chromebook Battery Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron 7486 Chromebook Battery Replacement: Schritt 6, Bild 3 von 3
    • Pull the tab on the battery cable to disconnect it from the motherboard.
    • Remove the battery.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
[deleted]
265 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 54
Letzte 30 Tage: 83
Insgesamt: 1,306
