Einleitung
By following the steps in this guide one should be able to replace the battery on the device (Dell Inspiron 7568).
Was du brauchst
Remove the ten 7mm Phillips #1 screws on the bottom cover.
Remove the bottom cover.
Remove the four 3mm Phillips #1 screws holding the battery.
Unhinge the connector cable to the battery.
Remove the battery.
5 weitere Personen haben diese Anleitung absolviert.
