Einleitung
By following the steps in this guide one should be able to replace the complete display assembly on the a Dell Inspiron 7568.
Was du brauchst
Remove the ten 7mm Phillips #1 screws on the bottom cover.
Remove the bottom cover.
Remove the four 3mm Phillips #1 screws holding the battery.
Unhinge the connector cable to the battery.
Remove the battery.
Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) and the cable bracket, above the motherboard
Doing this will allow one to access the LCD-motherboard connector cables.
Unscrew the 7mm screws that secure the left and right hinges (using a ph1 screwdriver bit).
Disconnect the antenna cable (under the left hinge)
Disconnect the LCD and Touchscreen display cables under the right hinge.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
