Zum Hauptinhalt wechseln
Dell Inspiron 7568 Display Assembly Replacement Guide
Was du brauchst
  1. Dell Inspiron 7568 Display Assembly Replacement Guide, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 7568 Display Assembly Replacement Guide, Battery: Schritt 1, Bild 2 von 2
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Display Assembly Replacement Guide: Schritt 2, Bild 1 von 2 Dell Inspiron 7568 Display Assembly Replacement Guide: Schritt 2, Bild 2 von 2
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Display Assembly Replacement Guide, Display Assembly: Schritt 3, Bild 1 von 2 Dell Inspiron 7568 Display Assembly Replacement Guide, Display Assembly: Schritt 3, Bild 2 von 2
    • Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) and the cable bracket, above the motherboard
    • Doing this will allow one to access the LCD-motherboard connector cables.
  4. Dell Inspiron 7568 Display Assembly Replacement Guide: Schritt 4, Bild 1 von 2 Dell Inspiron 7568 Display Assembly Replacement Guide: Schritt 4, Bild 2 von 2
    • Unscrew the 7mm screws that secure the left and right hinges (using a ph1 screwdriver bit).
  5. Dell Inspiron 7568 Display Assembly Replacement Guide: Schritt 5, Bild 1 von 3 Dell Inspiron 7568 Display Assembly Replacement Guide: Schritt 5, Bild 2 von 3 Dell Inspiron 7568 Display Assembly Replacement Guide: Schritt 5, Bild 3 von 3
    • Disconnect the antenna cable (under the left hinge)
    • Disconnect the LCD and Touchscreen display cables under the right hinge.
    • These are a set of two cables. For better image see image two in step one of this guide.
  6. Dell Inspiron 7568 Display Assembly Replacement Guide: Schritt 6, Bild 1 von 1
    • Carefully separate the screen from the bottom half of the device.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Yash Samant
394 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S2-G2, Lacy Spring 2017 Mitglied von USF Tampa, Team S2-G2, Lacy Spring 2017
USFT-LACY-S17S2G2
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 1,062
