Zum Hauptinhalt wechseln
Dell Inspiron 7568 Trackpad Replacement Guide
Was du brauchst
  1. Dell Inspiron 7568 Trackpad Replacement Guide, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 7568 Trackpad Replacement Guide, Battery: Schritt 1, Bild 2 von 2
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Trackpad Replacement Guide: Schritt 2, Bild 1 von 2 Dell Inspiron 7568 Trackpad Replacement Guide: Schritt 2, Bild 2 von 2
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Trackpad Replacement Guide, Track Pad: Schritt 3, Bild 1 von 2 Dell Inspiron 7568 Trackpad Replacement Guide, Track Pad: Schritt 3, Bild 2 von 2
    • Unplug the speaker cable and remove the speakers
  4. Dell Inspiron 7568 Trackpad Replacement Guide: Schritt 4, Bild 1 von 2 Dell Inspiron 7568 Trackpad Replacement Guide: Schritt 4, Bild 2 von 2
    • Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) holding the touchpad bracket
    • Remove the touchpad bracket
  5. Dell Inspiron 7568 Trackpad Replacement Guide: Schritt 5, Bild 1 von 3 Dell Inspiron 7568 Trackpad Replacement Guide: Schritt 5, Bild 2 von 3 Dell Inspiron 7568 Trackpad Replacement Guide: Schritt 5, Bild 3 von 3
    • Use a nylon spudger to lift the ZIF connector tab. Gently pull the touchpad ribbon cable free.
    • Use a nylon spudger to lift the ZIF connector tab. Gently pull the keyboard daughter board ribbon cable free.
  6. Dell Inspiron 7568 Trackpad Replacement Guide: Schritt 6, Bild 1 von 3 Dell Inspiron 7568 Trackpad Replacement Guide: Schritt 6, Bild 2 von 3 Dell Inspiron 7568 Trackpad Replacement Guide: Schritt 6, Bild 3 von 3
    • Remove the touchpad foil using a spudger or other ESD safe blunt-tip tool.
    • Unscrew & remove the three 2mm wafer screws holding the touchpad.
    • Remove the touchpad.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Yash Samant
394 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S2-G2, Lacy Spring 2017 Mitglied von USF Tampa, Team S2-G2, Lacy Spring 2017
USFT-LACY-S17S2G2
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 322
