Zum Hauptinhalt wechseln
Dell Inspiron 7573 2-in-1 Battery Replacement
Was du brauchst
  1. Dell Inspiron 7573 2-in-1 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 7573 2-in-1 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure computer is off before you begin.
    • Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
    • Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
  2. Dell Inspiron 7573 2-in-1 Battery Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 7573 2-in-1 Battery Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 7573 2-in-1 Battery Replacement: Schritt 2, Bild 3 von 3
    • Using a spudger, pry off the bottom cover by gently prying from corner to corner in order to disengage the plastic clips.
    • Lift off the bottom cover.
    • After the base cover is removed, your laptop should look similar as depicted in the images provided.
  3. Dell Inspiron 7573 2-in-1 Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the four 3 mm screws holding the battery in place with a Phillips #00 screwdriver.
  4. Dell Inspiron 7573 2-in-1 Battery Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 7573 2-in-1 Battery Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 7573 2-in-1 Battery Replacement: Schritt 4, Bild 3 von 3
    • Using the pull tab, disconnect the battery cable from the system board.
    • Lift the battery out from the laptop case.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kylie Freese
405 Reputation
3 Anleitungen geschrieben
Casper College, Team 1-2, Lareau Fall 2021 Mitglied von Casper College, Team 1-2, Lareau Fall 2021
CASC-LAREAU-F21S1G2
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 16
Letzte 30 Tage: 47
Insgesamt: 2,291
