Zum Hauptinhalt wechseln
Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement
Was du brauchst
  1. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure computer is off before you begin.
    • Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
    • Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
  2. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: Schritt 2, Bild 3 von 3
    • Using a spudger, pry off the bottom cover by gently prying from corner to corner in order to disengage the plastic clips.
    • Lift off the bottom cover.
    • After the base cover is removed, your laptop should look similar as depicted in the images provided.
  3. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: Schritt 3, Bild 1 von 1
    • Remove the four 3 mm screws holding the battery in place with a Phillips #00 screwdriver.
  4. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: Schritt 4, Bild 3 von 3
    • Using the pull tab, disconnect the battery cable from the system board.
    • Lift the battery out from the laptop case.
  5. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement, Memory Modules: Schritt 5, Bild 1 von 2 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement, Memory Modules: Schritt 5, Bild 2 von 2
    • Peel back the mylar coverings on the RAM chips on the right side of the system board.
  6. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: Schritt 6, Bild 3 von 3
    • Push outward on the two gray tabs on either side of the RAM module.
    • These tabs hold down the RAM modules, which should pop up when disengaged.
    • Gently pull the memory module out of its slot.
    • Be sure to only touch the edges of the RAM module, as the oil from your fingers can damage the components on the face.
  7. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: Schritt 7, Bild 1 von 1
    • With the new memory module, line up the notch on the memory with the tab on the module slot.
    • Insert the memory module at an angle.
    • Push down on the module until the locking tabs on either side click into place.
    • If there is no click, reinsert the module.
  8. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: Schritt 8, Bild 1 von 1
    • Repeat steps 5-7 for the other memory module.
    • In this laptop, one set of tabs was gray plastic and the other was metallic.
    • When pushing down on the memory modules, make sure you hear a click.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Brady Kennedy
109 Reputation
1 Anleitung geschrieben
Casper College, Team 1-2, Lareau Fall 2021 Mitglied von Casper College, Team 1-2, Lareau Fall 2021
CASC-LAREAU-F21S1G2
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 238
