Zum Hauptinhalt wechseln
Dell Inspiron 7586 2-in-1 SSD Replacement
Was du brauchst
  1. Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: Schritt 1, Bild 1 von 3 Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: Schritt 1, Bild 2 von 3 Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: Schritt 1, Bild 3 von 3
    • Flip the laptop over so the bottom is facing up.
    • Use a Phillips #00 screwdriver to remove nine screws from the back case.
    • Insert an opening tool or spudger in the seam between the back case and the body of the laptop.
    • Work your way around the perimeter of the laptop and release the clips that secure the back case.
    • You will hear a clicking sound as the the clips are released and the back case is being removed.
    • Remove the back case.
  2. Dell Inspiron 7586 2-in-1 SSD Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 7586 2-in-1 SSD Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 7586 2-in-1 SSD Replacement: Schritt 2, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the single screw securing the NVME drive.
    • Once the screw is removed, the SSD should pop up.
  3. Dell Inspiron 7586 2-in-1 SSD Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 7586 2-in-1 SSD Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 7586 2-in-1 SSD Replacement: Schritt 3, Bild 3 von 3
    • Gently slide the SSD out of the slot.
    • Make sure to gently pull out the drive to avoid damaging the M.2 slot where you insert the new SSD.
  4. Dell Inspiron 7586 2-in-1 SSD Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 7586 2-in-1 SSD Replacement: Schritt 4, Bild 2 von 2
    • Align the tooth edge of the SSD with the indents on the drive socket and gently insert the replacement SSD.
    • Press down on the SSD so the screw hole and drive align.
    • Use a Phillips #00 screwdriver to replace the screw.
    • Don't be scared to push down on the SSD as it should be level with the rest of the components.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Mike03
139 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 7-1, Grodsky Spring 2024 Mitglied von CSU Los Angeles, Team 7-1, Grodsky Spring 2024
CSULA-GRODSKY-S24S7G1
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 70
