Einleitung
Does your battery life seem to be diminishing? Are you constantly in search of a power outlet in public spaces? It may be time to replace the battery in your device; this guide will reduce your charging time and double your screen time! Inside the device lies a 68 Wh Standard Rechargeable Dell Li-ion Battery. The following guide will illustrate the steps to replace this vital component.
Was du brauchst
Use a Phillips #000 screwdriver to remove seven screws securing the base face of your device.
Unscrew the remaining two screws in the corners closest to the bottom of the base of the laptop.
Using a Jimmy, work your way around the edge of the back panel and the side of the laptop to remove the back panel.
Separate the remainder of the paneling using an Opening Pick.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
