Einleitung
This guide shows you how to remove the cooling fan in your Dell Inspiration 8600. The cooling fan regulates the computer's temperature. First you must remove the hinge cover and keyboard lower case to finally have access to the cooling fan.
Was du brauchst
Remove both screws from the fan using a Philips head screwdriver.
Slide off the cooling fan.
Eine weitere Person hat diese Anleitung absolviert.
