Zum Hauptinhalt wechseln
Dell Inspiron 8600 LCD Replacement
Was du brauchst
  1. Dell Inspiron 8600 LCD Replacement, Hinge Cover: Schritt 1, Bild 1 von 3 Dell Inspiron 8600 LCD Replacement, Hinge Cover: Schritt 1, Bild 2 von 3 Dell Inspiron 8600 LCD Replacement, Hinge Cover: Schritt 1, Bild 3 von 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  2. Dell Inspiron 8600 LCD Replacement: Schritt 2, Bild 1 von 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  3. Dell Inspiron 8600 LCD Replacement, Display Module: Schritt 3, Bild 1 von 2 Dell Inspiron 8600 LCD Replacement, Display Module: Schritt 3, Bild 2 von 2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  4. Dell Inspiron 8600 LCD Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  5. Dell Inspiron 8600 LCD Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 8600 LCD Replacement: Schritt 5, Bild 2 von 2
    • Lift the display module directly upwards from the base of the computer.
  6. Dell Inspiron 8600 LCD Replacement: Schritt 6, Bild 1 von 1
    • Now remove the display module.
  7. Dell Inspiron 8600 LCD Replacement, LCD: Schritt 7, Bild 1 von 3 Dell Inspiron 8600 LCD Replacement, LCD: Schritt 7, Bild 2 von 3 Dell Inspiron 8600 LCD Replacement, LCD: Schritt 7, Bild 3 von 3
    • First, remove the plastic tabs that are covering the interior screws.
    • After removing the tabs, remove the interior screws using a #1 Philips Screwdriver.
    • Note there are 8 tabs and 8 screws in total.
  8. Dell Inspiron 8600 LCD Replacement: Schritt 8, Bild 1 von 1
    • Now that the screws are removed, press the plastic casing inward to loosen the case. Then remove the plastic case from the monitor unit.
  9. Dell Inspiron 8600 LCD Replacement: Schritt 9, Bild 1 von 1
    • Using a Philips #1 screwdriver remove the screws holding the LCD in place.
    • Note there are 8 screws in total for this step, 4 on each side of the unit.
  10. Dell Inspiron 8600 LCD Replacement: Schritt 10, Bild 1 von 1
    • Remove the broken LCD unit, and replace with new unit.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Perry
251 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 18-22, Garner Spring 2011 Mitglied von Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Mitglieder
16 Anleitungen geschrieben
Ein Kommentar
which controller board do i have to use for this model ?
bcdoor - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 4,685
