Einleitung
If the LCD screen is not working, it may be a problem with the video card.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the battery from the bottom of the laptop.
Please click on the following link for further instruction on how to remove the battery. Dell Inspiron 9100 Battery Replacement
Insert a spludger into the notch at the far left side of the top blue panel and pry the hinge cover off.
You may need to pry the other side off as well. You can do this by inserting the spludger between the hinge and the top cover.
Pull the small black tab on the right hand side of the laptop.
You have now removed the hinge cover.
Remove the screws at the top of the keyboard as indicated.
You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
The keyboard should be easily removable at this point.
After removing the keyboard, locate and remove the labeled screws.
Gently lift the Video Card unit for replacing.
3 weitere Nutzer haben diese Anleitung absolviert.
