Zum Hauptinhalt wechseln
Dell Inspiron 910 RAM Replacement
Was du brauchst
  1. Dell Inspiron 910 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop so the battery is facing upwards.
    • Push the battery release tabs toward the center of the device.
    • Remove the battery.
  2. Dell Inspiron 910 RAM Replacement, Preparation: Schritt 2, Bild 1 von 1
    • Remember to power off the device before starting!
    • Disconnect any cables or external devices from the laptop, then flip it and remove the battery by pressing the battery tabs inward.
  3. Dell Inspiron 910 RAM Replacement: Schritt 3, Bild 1 von 1
    • Locate the large black panel with two screws holding it in place. (This is the panel with ventilation holes)
    • Unscrew both of the screws using a Philips Screwdriver.
  4. Dell Inspiron 910 RAM Replacement: Schritt 4, Bild 1 von 1
    • Remove the panel by pulling upward.
    • Removal may require some force!
  5. Dell Inspiron 910 RAM Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 910 RAM Replacement: Schritt 5, Bild 2 von 2
    • After removing the panel, locate the memory modules.
    • Look for the silver tabs on either side of the white plastic holding the RAM in place. Then gently remove the RAM.
  6. Dell Inspiron 910 RAM Replacement, For Reinstallation: Schritt 6, Bild 1 von 1
    • Depress the RAM until it locks into place; there should be an audible clicking noise when it does so and the gold contacts should be barely visible.
    • Congratulations! You have completed the guide.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Kyle Beekman
144 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 14-10, Forte Spring 2012 Mitglied von Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 21
Insgesamt: 2,946
